I ran 22mm cold from mains to the combi, combi is near were cold mains enters the building and kept the cold in 22mm till after it has feed the kitchen and the first two bathroom. It then reduces to 15mm to feed one more bathroom and cloak room toilet and basin. Hot is all in 15mm as this is what the combi outley is. Tiny bit concerned that having some of the cold first fix in 22mm and the hot in 15 (limited to this by the combi outlet). Will give different pressures on the hot and cold as the larger 22mm pipe will reduce the pressure though will increase the flow. Or is the effect of this negligible?
