15mm or 22mm
22 Apr 2005
Cumberland
I am about to have a combi boiler (Baxi 100HE) fitted in a 4 bed semi but prior to that am just relocating some radiators upstairs. Having lifted the floor boards I see that there is 22mm pipe coming upstairs from the back boiler which then converts to 15mm at the first radiator. All subsequent pipework upstairs is 15mm and there are 6 radiators coming off it. Should I be thinking about changing the main flow and return pipe to 22mm leaving 15mm for each radiator flow and return that comes off it or can I leave things as they are?
This could be a very long reply..who is converting your system? & whoever it is will need to know exactly how...
I would have thought the real issues would be whether the Combi will give you enough hot water which I doubt.
gazthepottertonengineer said:
i hate to tell you this but baxi 100HE isnt a Combi :rolleyes:
LOL :p :p :p :p :p
Well dang my old boots is that right :LOL: :LOL:
DIA maybe you should have said ` wall mounted powered flue condensing boiler` Happy Gaz?... ;)
You certainly will have to change all sorts of pipework me old mucker...think you would need a professional....for a start he will have to work out your existing plumbing arrangement, then use all pipework to suit the new...it`s a big job if you don`t know what you`re doing, I`m not suggesting you are incapable but probably inexperienced...I may be wrong but judging by your questions I would think that you will need the help of an experienced plumber/ gas fitter at least... ;)
Why the poster said it was a combi, ain't he gonna get a suprise when he opens the taps :LOL: :LOL: :LOL: :LOL: :LOL:
Perhaps he means the 130HE :rolleyes: :rolleyes:
Anyways how the hell do you expect me to know I don't fit the cans.
doitall said:
[quote=":
Errr.. not really, if he turns on his hot water taps he`ll get hot water...he won`t notice any particular difference.... ;)
Sorry DIA you mean Hot water pressure.. miles away...he certainly will... :D :D
Where's the hot water coming from then trainee, unless he plumbs the taps into the heating circuit. :LOL: :LOL:
Sorry DIA he`s converting from a back boiler system to a condensing boiler system..Can`t understand what your point is...
Try and keep up Trainee :LOL: :LOL:
The poster is fitting a 100HE which isn't a combi, although he assumed it was.
Therefor when he opens the taps = no hot water unless he keeps the cylinder, which would be a good idea
