15mm or 22mm
irvo the conventionally used maximum that can be fed from 15mm is about 4 kW, so it depends how big your radiators are.
In practice it will also depend how far they are from the boiler, etc. The figure can be worked out from a given temperature drop across the system, maximum desirable flow rate of the water, pipe resistance etc. If you use a figure around 3kW you should be able to get the full amount of energy from the rads.
The same sums would tell you that you need 28mm pipe from a 100,000 Btu/hr (approx 28kW) boiler, though boilers of that size typically have 22mm connections! Some mfrs DO tell you to go up to 28mm from the 22.
I disagree that any of this stuff is remotely difficult. If you want to find out about it, half an hour with a library book will tell you most of what you need to know.
