15mm to 10mm reducers
11 Feb 2007
Yorkshire
hello,
I've got 10mm microbore pipe to my Rads, and just fitting a towel radiator.
Bought some reducers - two piece brass type, without olives from screwfix
Should these be tightened like a 'normal compression' with olive, and should i use lsx sealer all around the reducer or none, or just on the cone parts of it?
Read somewhere that these only work if the microbore is absolutely bang in-line with the fitting?
thanks[/img]
It normal breaks in to 2 pieces when you tighten nut, the smaller ring the becomes the olive.
You could use some jointing paste or Lsx if you want, wont do any harm.
