I'm currently in the process of upgrading a little outbuilding. It was an old toilet from the late 1800's , but i'm planning to put a shower in it too.
It currently just has a single light on the ceiling on very old cable so i'm looking to re-run this from the house so it can take the load and be nice and safe.
The building is aprox 25m away and the current wire is clipped near the top of a 3m wall inside what looks like PVC mains water pipe (so this will be changed too to whatever is cheap/effective).
I'm looking at a 7.5Kw cheap shower , lighting and i might even put a plug in so i can make a cup of tea while i'm out and about, but overall it should be ~40amps.
A relative has advised i use 16mm mains tails, but these appear to be very expensive over this kind of distance so i was wondering if 16mm T&E would do the job as its considerably cheaper and on paper has a rating of over 70Amps.
I'm also considering not using duct and just clipping 16mm SWA, but this seems to work out more expensive than ducted T&E.
I plan to do most of the manual labour myself and hopefully find a good electrician to do all the connections and check it over.
thanks and hopefully i've not said anything too stupid on my first post!
