That's a challenge
Perhaps the Trappist set for him
An interesting observation.You could start an argument in a monastery, b-a-s![]()
Which one(s)?The regs state 0.05 ohm.
http://www.csecables.com/acatalog/SWA_.htmlWhere did you see it for £2.90?
It will.I've been looking at 3-core though as i assumed it would need an earth.
What do you think the armour does?
Trivial.Difference £27.50
Less than the price of a takeaway curry for two.
If £27.50 is so significant that you would avoid using the right cable to save it then you should not be doing this project at all.
You can use just the armour of SWA as the earth/CPC, in which case you only need 2-core, or you can use a third core of 3-core SWA (usually together with the armour). Opinions about this vary. Some say that to pay for a third core is unnecessary; others say, similar to you, that they are unhappy with relying only on the armour because, if the outer sheathing splits, it theoretically can corrode. I think it's fair to say that both approaches are widely used. As far as I am aware, the only downside of using 3-core is a small increase in cost. The great majority of 3-core SWA has brown/black/grey cores (rather than brown, blue and G/Y), suggesting that the manufacturers believe it is to be used for 3-phase (without neutral), rather than as "L, N & E".Excuse my ignorance, but if you use the armour as the earth (if i'm reading your comment correctly), what is the third core for on 3-core SWA? I figured the armour was just armour and you won't want potential current running through it in case the casing split.
What the OP requires is an electrician to do the things which he'll be expecting him to certify that he did, such as design.This thread seems to be going on a tour of all the options and purpose of various parts rather than determining what the OP may actually require.
Influx:
You have stated that the water pipe is not an extraneous-c-p; have you answered whether there are any other e-c-ps - metal parts emerging from the ground?
