Slope the ground at its angle of repose and don't have a wall at all. Or do a half and half: reduce the height of the wall ans slope the ground back from the top of the wall. Or use something like Kriblok
There is alot of Rock in the hill and with the dirt it pretty much does not move.
I was hoping that with the wall and back fill it would compact it more so when it rains it doesn't let any of the loose hill wash out or down.
I plan on connecting a horizontal concrete square type with rebar in it to one end of existing cement water tank. ( tank is 1.5 X7meters made form same blocks all canals filled with rebar in each canal) Interlocking the two at the 17 foot mark.
The first 7 feet of the bottom of the hill is pretty much all rock so it doesn't move.
