So if someone wanted you to add a new light switch in their bedroom, using surface mounted cable, would you want to put the circuit on an RCD?
no as you know it's not required
But what if (as is nearly always the case) that lighting circuit also goes into the bathroom?
You've added to a circuit supplying the bathroom, so why don't you have to bring it up to the requirements of the 17th?
You know full well that the existing circuit has unprotected cables concealed at <50mm depth in walls or partitions, and that the 17th requires them to have RCD protection.
You've added to the circuit, so why don't you have to bring the whole of the existing circuit up to the requirements of the 17th?
What if they wanted a light put in the cupboard under the stairs where their CU was, and they wanted it on a socket circuit (pre-17th, no RCD) so that they could still see to reset the breaker of the lighting circuit when it tripped. All the cables are on the surface, and they're quite happy with surface mounted accessories. Would you want to put the socket circuit on an RCD?
Here again there is no requirement to supply any lights from an RCD which the exception of bathrooms so no.
But what if that socket circuit supplied a heated towel rail in the bathroom - would you need to put it on an RCD?
Also you know full well that the sockets already there aren't RCD protected, and that the 17th requires them to be.
So is a spurred socket a circuit?
Maybe if from FCU then it would be new circuit but if not the no it is not a new circuit.
But according to you there'd be no point in ever having a spurred socket not coming from an FCU, as that's not a circuit, so according to you it won't work:
But if it is not a CIRCUITS then it will not work.
If you took on a job, and the specification said "install circuit to supply <thing>" and you spurred off from the nearest convenient existing circuit, would you think that you'd fully met the spec?
How many times have you pointed out one has to be sure any additions do not compromise the existing installation and you may as well ask the length of piece of string.
That's not an answer to the question.
If you were asked to install a circuit, and instead you installed a spur (fused or not) would you think you'd done what was asked?
Circuit = An assembly of electrical equipment supplied from the same position at which electrical energy is delivered to an assembly of associated electrical equipment having co-ordinated characteristics to fulfil specific purposes and protected against overcurrent by the same protective device(s).
That's not the definition in BS 7671.
Anything designed after 30th June 2008.
The existing circuit was not designed after 30th June 2008.
What was designed after 30th June 2008 is the addition of the fan, so it's that addition that has to comply, not what's already there.
That's what we said the fan needs RCD protection. As will the shower.
I'm not disagreeing about the new shower circuit.
But where's the regulation which says that the fan needs RCD protection?
