Just fitted one of them new fangled 17th edition CU jobbies.
What do you reckon?
What do you reckon?
I reckon it's good that MK are upholding their tradition of slightly askew modules.Just fitted one of them new fangled 17th edition CU jobbies.
What do you reckon?
little led's on the mcbs? wicked
Maybe not on a per-circuit basis, although I guess that could be done relatively easily with a bit of intelligence in MCBs.And a USB port so you could download the power and current loading history. That could link to a central server in France and you could then be billed on a per circuit basis.
What do the 5 cbs in the middle serve
How are the cables run from those (buried or trunking) or is this supervised environment.
That B40 at the end on the right looks a bit lonely!
PS Would have looked better if the RCBOs were all the same MK generation and grouped together.
The new RCBOs are so well designed that an insulated pozi screwdriver is to fat to fit into the hole to tighten up the outgoing neutral terminal.
