17th stuff, 3rd time lucky
Until you stop telling lies.
If anyone's the liar, it;s you.
Simple question - simple answer - will you - yes or no?
How many times do you want me to answer? No matter how much you badger, harrass and twist, I've given my answer. What you have not done is to give any logical or reasonable reply to my answer.
You and eric claim that the former allows you to leave the circuit non-compliant with the 17th but the latter does not.
Another scandalous lie from you - should we expect any different? I'd ask you to point out where both us explicitly said that, but you'll probaby revert to your usual desperate trick of cutting a word from here, another from there and pasting them to make it look like a complete answer. You just can't help yourself can you? :roll: :roll: :roll: :roll:
So your tactic will be to inflame the situation to provoke responses which in turn will lock the thread - thus saving you from the shame of being wrong and being seen to be wrong.
hi
i have read the whole thread and have found it very thought provoking, though sadly, abusive at times. nevertheless i have now come to my conclusion.
looking on-line at this dictionary i found
http://www.merriam-webster.com/dictionary/alter
so working this in to the regs i am finding myself starting to reject this "like for like" interpretation of the ESC.
if you change a fitting for a new one (damage or cosmetic) you should modify the circuit to the 17th. this would be especially true in a special location as compliance with part p is through adherance to chapter 13.
that said then, a replacement in say a bedroom would be non-notifiable so perhaps you could pop it on a non modified circuit noted as a departure.
Not sure I agree with you PartP.
First: your definition
Alter - to make different without changing into something else.
(note: BS7671 doesn't use this word, it uses the word 'alteration'.
If it's like for like, it's not different. It doesn't alter the characteristics, loading, danger, safety of the circuit or installation etc.. Standard Circuit Arrangements for lights, for example, assume a distributed loading of 10 (or is it 12?) 100W light bulbs so as to allow a couple of 300W fittings, so even if the new light was one of increased load, there is an argument to say it is still like for like as far as the Standard Circuit Arrangement is concerned (unless most of the lights are greater than 100W).
Seems sensible to me that a light on the stairs should be replaced without fuss. I'm sure the same could be said of a bathroom, if only to prevent the tempation of trailing an extension lead in there and balancing a table lamp on the edge of the bath.
Also, Part P does not require certain work to be notified - 'replacing any fixed electrical equipment' is one of them. Although 'light fitting' is not specifically mentioned in Approved Doc P as an exhaustive list is not preseted, it's fair so assume that a light fitting should be treated the same as a socket outlet, or ceiling rose.
Eitherway, it weakens BAS's argument further.
A professional electrician should still complete a Minor Works ( :wink: )and 1.4 last para in GN3 should be noted (633.2)
The thrust of this thread and the preceeding thread was to do with a CU replacement.
As for other work, it must be taken on merit each time, taking into consideration the extent of the work and the condition of the installation.
I don't think a list of all permuations could be made.
In general, Minor Works would not involve significant upgrading of an installation - assuming that there is an effective means of earthing and such like. If there isn't, the value of the job is probably low so that a professional electrician could 'walk' rather than take on an ambiguous liability.
This brings us to the main thrust of this thread - the third in a row - which relates to changing a CU. Some stated that changing a CU was no different to replacing a light fitting - in terms of liability and the requirements of the Regs and that any remedials could simply be ignored and listed as 'departures'. I disagreed. I argued that unless the electrician could prove otherwise, he had to assume that all circuits did not meet the 17th's requirements for impact protection and should be protected by a 30mA RCD. After this, other points were raised such as main protective bonding etc. It seems pointless to repeat everything as this thread and the other two are there to be read - even if locked.
There is an 'economic' question to be answered when quoting for a board change. Go overboard and you won't get the work. But if there is no means of earthing, no protective bonding, undersized tails etc. what is an electrician to do? Further more, what will his Scheme have to say on the matter?
There is a chance that upgrading a main bond is actually more expensive than the board change. So, if it's 6mm - would it be fair to leave it and note it as an observation and departure? Perhaps that is for another thread.
BAS says that you should be able install a new 'split load' consumer unit (let's call it a '16th')- RCD protection for sockets, none for lights (without cpc remember).
Where?
All I have done is to keep asking you to show where I said what you claim I have.
Either you know you can't, in which case you know that what you are saying is untrue (and I invite you to reflect on the word commonly used to describe a person who knowingly says things which are untrue), or you know that you can but you are refusing to do so in order to perpetuate this pointless spat, which is entirely of your making, rather than taking the opportunity to prove that I'm wrong.
Which is it?
There is no regulation (AFAIK) which discriminates between changing a light and adding one - 131.8 for example groups alterations and additions together.
131.8 for the umpteenth time :roll: (and to prevent a nit-pick, we are talking about a like for like replacement).
131.8 does not discriminate between alterations and additions - it classes them as one in terms of what you have to do to ensure their safety.
Then what are you blithering on about? How many times are you going to change your mind? I've lost count.
I've not changed my mind once - what I said there was exactly the same as what I said earlier.
There probably isn't in BAS7671...who cares ? :roll:
If there is one in BS 7671:2008 which supports your position will you tell us what it is?
Actually, I have:
Is a like for like replacement an alteration - No.
According to my dictionary it is.
Are we to take it then that your position is based on the notion that you can change something on a circuit and not alter it?
Alter: vb to make or become different in some respect; change.
If you replace a light, the light is not the same one that was there before, it's a different one, therefore there has been a change, therefore, as BS 7671 does not define the term "alteration", the normal English definition applies, therefore replacing a light is an alteration.
I have never conjoined extracts, phrases or words from different posts to make them appear to be a complete sentence or post that never actually existed.
But I'll be ultra-scrupulous now, so I'll ask people's forgiveness for what will be a long series of quotes. I'll quote posts in their entirety- that way the entire post can be seen, and I can't be accused of only quoting what suits me, but I'll highlight the relevant parts that I would normally have cut out so that it's easier to follow the thread,
The exchange with eric:
What about adding lights to the circuit?
Then your addition must comply with the current edition of the Regs.
This is like pulling teeth isn't it.
If you were adding lights to an existing bathroom circuit, do you think that you would have to add RCD protection to that circuit?
It's a circuit with cables concealed in walls or partitions at a depth of less than 50mm in an installation not under the supervision of a skilled or instructed person.
See above.
See above.
If you were changing a fuse or MCB for one of a different rating because the existing one was the wrong size, and the circuit had cables concealed in walls or partitions at a depth of less than 50mm in an installation not under the supervision of a skilled or instructed person would you expect to add RCD protection?
:roll: Then assume you were wrong :roll:
OK - so in a topic concerned with what people felt should be done in various scenarios of electrical installation work, I wrote the phrase "as soon as you've opened your toolbox and isolated a circuit" and you thought I was talking about someone turning off an MCB before going on holiday.
Fair enough :?
You've made an alteration to every circuit. It has everything to do with a CU change. The paid job you have taken on is to change the protection of the entire installation, so what excuse can there be for changing the protection to not comply with the 17th?
That was never my suggestion. My observation was that your comment, "If someone hasn't inspected 1st fix (i.e most of Cables and Conductors), it hasn't been signed for and it hasn't been done." was irrelevant to the issues surrounding replacing a CU.
To fingRinal it is immaterial if it is an MCB which is in turn feed from an RCD or to RCBO’s to cure the problem one way would be to combine both circuits and yes I also think in the main will be the norm in my house all lights from day one have always been on one circuit and to prevent danger should the MCB or RCD trip the stairs/landing and garage both have battery backed lights.
To ban-all-sheds “If you were adding lights to an existing bathroom circuit, do you think that you would have to add RCD protection to that circuit?” yes as it is an addition if the customer does not want the expense he/she has no need to add to the circuit. If however I was replacing a faulty existing lamp then no.
I do see a problem if a new lamp wired in Ali-tube cable is added to a circuit which has some areas where the cable is buried to less than 50mm then since the new bit conforms no you don’t need to add RCD protection.
“If you were changing a fuse or MCB for one of a different rating because the existing one was the wrong size” if you can’t use a RCBO and the MCB was wrong size due to something that happened in the past than changing the MCB for another MCB of different rating is OK. However if the board would take a RCBO or the reason why the MCB required changing was due to some upgrade you had just completed i.e. change of shower size then one does need to upgrade to take a RCD. If good cause can be given i.e. 7kW showers no longer produced then I would say it was OK just to fit a replacement MCB.
“Quote:You've made an alteration to every circuit. It has everything to do with a CU change. The paid job you have taken on is to change the protection of the entire installation, so what excuse can there be for changing the protection to not comply with the 17th?”
I can’t see how this holds true remember we are not just talking about domestic and if I changed a distribution board I would only be concerned with cables directly leaving that board if one of those cables in turn feed another DB then I would not be concerned with the second DB. Returning to domestic a radial wired surface to first socket I would check the first socket before and after and if that’s OK that’s as far as I would go. If the customer wants a PIR he can pay for one it don’t come free with a Consumer unit change. We are permitted to stipulate limitation of work and that is what I would do.
Using a single RCD to protect all is not automatically against the 17th Edition only if it is likely to trip would it be against the 17th Edition and with caravans one is forced to use two RCD in series not parallel one outside caravan and one inside so where a customer is unwilling to pay for multi RCD protection then I see using a single RCD as only option left.
Again there comes a point where one has to use some common sense. If one reads “Best Practice Guide 1” from “The Electrical Safety Council” on lack of earths on lights it goes through a procedure of first trying to persuade the owner to do best option and if this fails it goes through other options one at a time and only if the owner insists on using Class I items does one refuse and walk away. And I think the same applies to every other job we do. First try for best and only if your actions would make the installation more dangerous than existing do you need to walk away from the job.
Eric
So I think that's covered off the eric exchange - I asked "If you were adding lights to an existing bathroom circuit, do you think that you would have to add RCD protection to that circuit?" and eric said "yes as it is an addition if the customer does not want the expense he/she has no need to add to the circuit. If however I was replacing a faulty existing lamp then no."
The exchange with you:
"Minimize" is an unfortunate word to have used, as it means to reduce to the least possible degree or amount, and the least possible amount of inconvenience in the event of a fault would be a CU with several 10's of RCBOs, with each individual socket, light, FCU and fixed appliance on their own dedicated circuit. And that's never going to happen.
In my opinion, you're focusing on the wrong word. 'Minimize' is attached to the word 'inconvenience'. It is the word inconvenience that is the main thrust of things. Once we have established what the inconvenience is or could be, we can decide what to do about it. The Regs would like us to 'minimise' it.
So, first of all we need to define what 'inconvenience' is. Inconvenience will change from installation to installation and from use to use.
Inconvenience to me is likely to mean something different to someone else. Also, in 10 years time, inconvenience may mean something different to me. But by then, a PIR will be due and the Inspector should take this into consideration.
For example, if you were replacing a light or a switch in a bathroom, would you expect to add RCD protection to the circuit?
Not at all. Assuming the replacement is of the original specification, the replacement can't be considered to be an addition or an alteration.
If you were changing a fuse or MCB for one of a different rating because the existing one was the wrong size would you expect to add RCD protection?
This would depend on the type of circuit, its use and other factors.
I don't believe that 131.8 means that as soon as you've opened your toolbox and isolated a circuit you're not allowed to turn it back on and leave until it complies with BS 7671:2008.
It doesn't state that at all. It refers to making additions and alterations and not to switching an mcb on or off (which you might do if you went away on holiday for example).
yet there also seems to be an insufficiently thought-through belief about "taking responsibility" for what's already there, particularly when replacing a CU.
Insufficiently thought-through by whom? It's insufficiently through-through if someone thinks responsibility can be ignored for reasons of convenience. If someone hasn't inspected 1st fix (i.e most of Cables and Conductors), it hasn't been signed for and it hasn't been done. I suppose the solution would be to amend the standard forms of BS7671 to include extras that the constructor could sign for as Inspector - assuming he is competent to do so.
Which is basically what I said when I talked about the user being the one who should decide what inconvenience is acceptable, but I appreciate the problems of having an informed discussion.
But if the idea is to "avoid danger and reduce inconvenience to a level acceptable to the user in the event of a fault", then if the user is happy with a dual RCD board it complies.
:roll: Was I wrong to assume that in the context of this topic people would take "opening your toolbox and isolating a circuit" to mean that they were doing some kind of work on it, not going on holiday? :roll:
That's nothing to do with a CU replacement.
Then we agree.
The Designer takes on an assumed responsibility to minimize to a reasonable level. He is the comptent person and can't ignore it altogether so a reasonable distribution of circuits in a dual RCD boards should suffice in many situations.
See above.
Insufficiently thought-through by whom? It's insufficiently thought-through if someone thinks responsibility can be ignored for reasons of convenience. If someone hasn't inspected 1st fix (i.e most of Cables and Conductors), it hasn't been signed for and it hasn't been done.
So I think that's covered off the exchange with you - if it hasn't, and I'm wrong, then I've genuinely made a mistake, and have not been posting scandalous lies.
If I have made a mistake, either because you've not been clear enough for me to understand you, or I've not paid close enough attention, then I will of course admit my error, and apologise.
So it seems to me that the quickest way to resolve this is for you to make an explicit clarification.
Consider a circuit with no faults, fully in compliance with the requirements of the 16th, but not in compliance with the 17th because it does not have RCD protection.
Here is the post where I made the the statement about what you and eric were saying - again I must apologise to the other readers of this forum, but I'm going to quote it in its entirety, with highlighting, so as to avoid any chance of being accused of desperately cutting a word from here, another from there and pasting them to make it look like a complete answer.
FR - why do you persist in saying things about me that aren't true?
FR - why do you persist in telling lies?
Surely if you want to show that what you say is true then when I ask you "where?" you should show us where, not just respond with 64 identical smileys?
How many times? :roll:
64 - what's the matter, can't you count?
Let's assume there are no other defects (as you like to assume things)...
It's the only way to get you to give a non-evasive answer to a simple and straightforward question...
Then what the heck are you talking about?
An existing lighting circuit which does not have the RCD protection required by the 17th, but other than that has no faults, and is part of an installation which has no other related faults.
On which we are either going to replace a luminaire or add a luminaire.
I'm interested in a logical and consistent reason why.
So to clear this up once and for all, can you please tell us in which of the following two scenarios you would leave the circuit without an RCD, and thus leave it non-compliant with the 17th, and in which you would add an RCD and thus leave it compliant with the 17th:
1) replacing an existing luminaire
2) adding a luminaire.
We can all make mistakes - I'm not ashamed of being wrong, which is why I keep inviting you to show where I did say that you should be able install a new 'split load' consumer unit (let's call it a '16th')- RCD protection for sockets, none for lights (without cpc remember).
Edited to remove accidentally duplicated text.
Nor I.
In which case if a 100W GLS luminaire was replaced with two separate 50W GU10 luminaires there would be an argument to say it is still like for like as far as the Standard Circuit Arrangement is concerned.
In which case could you clarify what you meant by "your addition must comply with the current edition of the Regs" in this exchange?:
I: For example, if you were replacing a light or a switch in a bathroom, would you expect to add RCD protection to the circuit?
You: Not at all. Assuming the replacement is of the original specification, the replacement can't be considered to be an addition or an alteration.
I: What about adding lights to the circuit?
You: Then your addition must comply with the current edition of the Regs.
Which argument is that?
The one where I said "131.8 does not discriminate between alterations and additions - it classes them as one in terms of what you have to do to ensure their safety", or the one where I said "If you're replacing a CU, I think on balance that you should use RCD devices to comply with the protection rules of the 17th"?
I guess you spent hours doing all that.
It may come as no surprise to you that I won't be reading it. It tired out my finger scrolling down to the bottom. I thought at one point my mouse was going to hold out for more rolled oats.
Until you are are prepared to grow up and join a mature, intelligent debate, you can include me out...
I think you should be congratulated on one thing. I think you should be in the Guiness Book of Records for the longest unbroken run of trolling. :D
Did you read all that? If you did, perhaps you could do me a favour and summarise a salient point or two? I'd be most grateful. :)
(whisper: I think it will be locked to save BAS's blushes - keep it under your hat though)
I must disagree...if she'd been your Uncle, I would say that counts as 3 points. But then it's 3 points less too - so perhaps it's all the same. I think what you meant to say was 'Monkey's Uncle'. :D
FR - I have shown where you and eric wrote the words which led me to make the statement about you were both saying.
Will you do the same for me?
I have given you the opportunity to clarify exactly what you meant, and to state unambiguously what your position is.
I have said I have made a mistake, either because you've not been clear enough for me to understand you, or I've not paid close enough attention, then I will of course admit my error, and apologise.
