My fiancee and I have had an offer accepted on our first house together and we had a full structural survey done on it (a 50's, ex-authority 3-bed end of terrace). The property is located in Kent, within the M25 (so close to London).
The survey has come back with a few things that worry us and I'm hoping someone here can give me some advice. The survey says:
- The flat roof on the extension apparently needs replacing immediately. The roof is about 2.5mx4m. Does anyone know how much this should cost?
- Tests revealed evidence of rising dampness to 3 of the walls (front, rear and left flank - all 3 external I assume) and that remedial treatment is necessary. They've said condensation isn't an issue but the property has been empty for at least the last few months. Do you think its likely to be a problem and how can I get a second opinion?
- They've noticed cracking to the front elevation and to the internal partitions and recommended we call in a structural engineer. Does anyone know how much this is likely to cost and can you recommend anyone?
Thanks for your help.
Adrian
Adrian
