H
holmslaw
my mums place was built in the early 60s and that's all stranded 2.5mm on the ring finals.
The cable is black / red ( guy installed it about a year ago])
Metric size cable didn't come into use until circa 1970, so it wouldn't be 2.5 sq. mm. Pre-metric rings were normally wired with 7/.029 (with 3/.036 earth).
Wasn't that a 3/.029 Earth (1.3mm²) ?
No, the earth size was chosen to be a minimum of half the c.s.a. of the circuit conductors, so 3/.029 would have been too small. 3/.036 was the smallest standard size which satisfied the requirements for 7/.029 circuit conductors.
The standard make-ups were:
1/.044 with 1/.044 earth
3/.029 with 1/.044 earth
3/.036 with 1/.044 earth
7/.029 with 3/.036 earth
7/.036 with 7/.029 earth
7/.044 with 7/.036 earth
7/.052 with 7/.044 earth
7/.064 with 7/.052 earth
Really, I'd love to know where I could buy stranded from as I've never seen anything but solid in metric sizes. Going solid was definitely a retrograde step and I suspect the manufacturers used the change as an excuse to cut manufacturing costsIts normal, 2.5 comes as solid core or stranded, 7 strands. Stranded is more flexible and stronger than solid core.
Ahh nostalgia, 7/029 - the only pre-metric cable size I know.Metric size cable didn't come into use until circa 1970, so it wouldn't be 2.5 sq. mm. Pre-metric rings were normally wired with 7/.029 (with 3/.036 earth).
