Hi everyone,
I have wired some 1.5mm 3 core SY flex from an existing socket to a new double socket in my shed, and I have used this same cable from the new socket to a fused spur.
I have then used some 2.5mm 3 core from the spur to a ceiling rose.
The fused spur came with a 32a fuse installed which I'm led to believe needs downgrading to a 5a fuse.
I was wondering if there would be any problems using 2.5mm in front of the 1.5mm? It works fine but I thought I would check.
Any yes it was a bitch to terminate!
Thanks.
Thanks.
