I recently removed a light from our new house to find 2 black wires, a green wire and a white wire hanging from the celing in 2 seperate terminal blocks.
Before i attach the new light with the usual brown/blue/green & yellow combo Id like to check how this matches up.
There are also 2 earth wires in the new light.
On the old light, one of these earth wires was connected to the 2 black wires seperately on a single terminal block. The other 2 wires - green and white were connected to another seperate terminal block.
The new light has a 3 terminal block.
What will the configuration in the three terminal be as there are 4 wires from the celing, 3 in the light + 2 earth wires from the light also ?
Any help much appreciated
Also after fitting a dimmer all the lights outside the room with the dimmer have gone but there is no fuse replacement in the old mains system for this and the switch in the box will not got on (remains in middle or off)
