electric lights problem
Before you go any further I would recommend you isolate the supply safely to the existing ceiling rose and sort the mess out in there!
i got it working
atr some point the bulb in the bedroom light has blown changed that and reconnected and tightened all wires and all is working as i hoped it would
many thanks for all the help offered by you all
i tried connecting the brown and blue from the wardrobe in terms 1 and 6 to see if i could just use the bedroom switch for both lights and the same happens, wardrobe works and the bedroom doesn't
Thats not true, from the info you've given terms 1+2 (switched live) are the same as are 5+6 (neutral). You previously said that when connected to terms 2+5 both lights came on together, therefore the same will happen when connected to 1+6.
Get an spark to sort it out and test your circuits - its very dangerous.
where did i say both lights came on together with 2 and 5?
i said the bedroom light switch turned on the wardrobe
the bedroom light was not coming on
Are you a politician?, because you lie like one.
what are you talking about ? ? ?
where am i lieing
more importantly why would i lie
i came on the forum asking for your help not you asking for mine so where is lying going to get me? wouldnt have got my problem sorted would it
boy ur on medication thats a little too strong u need to go back to the doc
