Yes, there's obviously always going to be a need for an exception to avoid that 'Catch 22', but I guess that can be largely served by a requirement to have an RCD 'close to the origin' of the installation, hence at least limiting the length of that unprotected cable. I was commenting more on the fact that this would seemingly allow an unlimited length of,say, T&E to exist without any RCD protection in a TT installation.No, that's exactly what it is saying, or how else would you get your electricity from the meter into the RCD enclosure?]any length of any cable with a non-metallic sheath (i.e. virtually any multicore cable) has 'adequate mechanical protection' for the cable to be unprotected by a RCD in a TT system. That doesn't really seem to be fully 'within the spirit', so I wonder if I'm misinterpreting?
Are you saying that this reg theoretically does not allow, say, an outgoing SWA cable to have its armour (and maybe CPC) earthed (or even 'exposed') in an enclosure which contains non-RCD protected conductors (e.g. the enclosure containing the most upstream RCD) in a TT installation? If that's the case, I guess one has to earth it only at the other end, and take steps to 'isolate' the upstream SWA gland; in practice, I suspect it would usually be simpler to run unarmoured cable (with CPC not connected at one end) to a second enclosure for the SWA termination?Note much thinking required there - the reg is for CPCs of other circuits, not the one connected to the RCD.Indeed. I find it difficult to be sure whether 412.2.2.4 theoretically allows a CPC to enter a pre-RCD Class II enclosure in order to connect to the armour (and CPC, if appropriate) an outgoing armoured cable - but, as others have said, I'm not at all sure that one should be doing this, whatever 412.2.4 may say. If the enclosure is the one which actually contains an RCD (so that the outgoing cable was RCD-protected, I suppose it could still be said that there was an issue with having a CPC within it, but that would perhaps be getting rather pedantic.
Kind Regards, John
