2 earths in double socket.
25 Jan 2006
Manchester
Hi (again)!
Currently installing a new double socket in the living room.
Fitted flush metal back plate in wall, channeled out the wall leading to the existing double socket (the only one in said living room - has two sets of cables running in so I assume this is good for a spur?...if not then I've not as yet got my head around extending ring mains - the fuse box has one sockets fuse for upstairs and downstairs).
So far so good :?: ...just nipping out to grab a grommet and earth sleeving for the cable (why aren't earths pre sleeved?).
However, in the existing (wall mounted - will flush this at later date) the earth cables from the two cables are on fixed seperately - is this a problem? Which one do I attach the cable from the new socket (spur) to - does it matter?
I'm sure this is basic science to you guys but I want to double check.
...and is it me or can you only purchase chrome sockets these days??
Many thanks.
Sounds like your existing socket is on a ring, but it'd be wise to verify this before taking a spur from it.
and doesn't matter which terminal you connect the earth to, if you look at the back of the socket you can see that both terminals are attched to the same piece of metal
and yes, you can buy standard sockets easily enough, I recommend you go for recognised make such as MK
The cpc's should not be twisted togethers as some are (twisting places mechanical stress on the conductors). They should be separately sleeved. If the outlet has two earth connections then the cpc's of the ring should connected, one to each. If you are spurring off a ring socket, add the cpc of the spur to one earth terminal and the link to the back box, to the other.
Many thanks for your help.
I can't see the existing socket being anything other than a non-spurred (I know all the tech jargon :) )socket - aside from the kitchen this is the only socket downstairs (feeding two 4x extension leads).
Plus there are two cables feeding this (which I took to assume this is not already a spur).
Awfully sorry - but this has left me a little confused (easily done when it comes to leccy tech speak!). Should I read this as the two earths from the existing socket should not be bound toegther and fed into one earth connector on the plate? And what is a 'cpc'?
Yours gratefully.
Yes one into each terminal and CPC = Circuit Protective Conductor (earth)
Cheers Qedelec you've been very helpful. I'll try and somehow drop CPC into the conversation in the pub later this evening - my, won't my friends be impressed!!
Forgot to ask if there is any definitive way to double check this as a rookie? This existing socket has been feeding two 4x extension leads for nigh on 5 years (yeah I know) so I assume a spur won't overload the ring it's on. The fuse box has been updated (I guess in the last 10 years - was in before we moved in 7 years ago and looks modernish) so I think a rewire job is not necessary.
nothing wrong with 4-way sockets, as long as you dont go plugging electric heaters or tumble dryers or toasters into them - in fact, they can be safer than some diy lash-ups.
True, though I need to add a lamp or two on the other side of the room and the mess of wires resembles amateur spaghetti!
Cheers.
