I don't think that sentence has the meaning you suggest. I think it literally means terminated (e.g. connected to a terminal block), not necessarily a terminal on the metal box. We discussed this here fairly recently, in relation to the need to run a CPC to any accessory, even if it is a Class II accessory which does not require a CPC (just in case someone subsequently changes it for a Class I one).I know the OP has stated that he is using plastic - but it seems to me that the last part of 411.3.1.1 , 'A cpc shall be run to and terminated at each point in wiring and at each accessory, except a lampholder having no exposed conductive parts and suspended from such a point', implies that you must run a fly lead from the socket cpc to the earth point on the metal box.
JohnD";p="1997083 said:The socket you already have is a spur off the ring.
are you sure about that?
Whoops, sorry
river,
i think i follow. the rcd seems to cover several different circuits, not just the heating/socket, if that makes any difference?
is it worth installing a fused connection unit?
whats an OP?!!
d
just been back with the tape measure,
the tricord from the CU is 4mm. shouldi still fit a FCU or just spur off the existing socket?
d
Yes it will be unsafe if the cable is 2.5mm from the CU and the MCB is 32Amp.argh!
if its meant to be 4mm squared then im not sure. tried to measure the widest part of the cable.
im not about to mess about with the CU, have no intention of changing the cable supplying the original socket.
i think i.m going to install a FCU before the existing socket then spur a second one after.
Unless this seems very unsafe to anyone?
d
This link may help you confirm the cable type:
//www.diynot.com/wiki/electrics:flatpvccables[/QUOTE]
He tried that here
Check here to be doubly sure you have the right size cable.
//www.diynot.com/wiki/electrics:cable_types:flatpvccables
