When I first read this thread, I just new some pillock was going to have to confuse things and mention high integrity earthing.
In the olden days 2008 we connected two earths (one from each leg of the ring into one terminal) however, in 2008 the selected people who make changes to the regulations decided it would be better, safer, and another change to the regs if we had two earth terminals , and to be trendy- called it "dual earth. If you want to earth the back box, thats "best practice" but no doubt a debate that will run for days…….. on this site.
If you want to connect an earth ( cpc ) if your street wise, you could use two terminals ……… but actually if the theory is correct the manufacturer should provide you with 3 !
Sorry guys, but I only have one earth cable, is that ok and do I need to worry about the earth to the terminal box? Can I just plug the one earth cable that I have into any of the earth terminal. Thanks again.
Back to the actual installation, if you only have one Earth lead, do you only have one L and N?Sorry guys, but I only have one earth cable, is that ok and do I need to worry about the earth to the terminal box? Can I just plug the one earth cable that I have into any of the earth terminal. Thanks again.
The people who mentioned it are not pillocks, the one who gave misguided information with regards to it, maybe is? But I will leave that verdict to your honourable self.
high integrity
You should have one earth from each "cable", by "cable" I mean the overall sheathed cable which should contain one Red (or Brown) Live, and one Black (or Blue) Neutral and one uninsulated Earth (which should be sleeved Yellow/Green within the fitting).Sorry me again, could someone jut explain while I only one earth cable and not one from each cable on the ring main like the live neutral? Do they all feed back to a central earthing terminal? Thanks again.
I only have one earth cable. Will try to post pic. Thanks. The house is only about 25 years old.
You can do either.Ok sorry there is 2 but just in the one cover so it just looked like one. Do I have to put one in each of the earth terminals on socket or can they just go into one? Thanks
