yorkspark said "In order to use the switch to feed another light fitting you will also need another twin and earth taking to the switch from the pendent then connect up as follows".
Does he mean twin and earth from the switch to the second pendant (that has no power) or from the 1st alongside the 3 core and earth.
At the moment I have 3 core and earth coming from the 1st pendant (with power) to the switch and twin and earth coming from the second light (no power) to the switch.
