2 Gang Switch Problem
11 Oct 2009
Lancashire
I am trying to re-wire a 2 gang switch which is causing me a problem. One switch is to control the bathroom light and the other is to control the kitchen light.
At the moment there is one red wire to L1 at the top, a small blue wire from COM to COM. There is also a grey casing containing earth, another red wire (which is wired to L2 at the bottom) and a black wire (which is wired to L1 at the bottom).
I know this is incorrect as the current set-up means of the switches will turn the light on and the other switch alternates between the two lights.
Can anyone help, this is causing me a nightmare!!
Thanks.
take the red that is in the top L1 and put it in COM with the blue wire..
take the red that is in L2 at the bottom and put it into L1 the the top
report back what happens
