Did you turn the problem one on and off a dozen or so times as I said they do stick when new? And if it stuck in the contact close position you will get the affect you are talking about.
I take it you did try the cables in the opposite gangs and the problem stayed in the same gang but other light. Just to confirm there are not wiring issues.
I have done - still no joy. Seems pretty conclusive.
Even as you suggest, having swapped the cables to the opposite gangs, same problem just with the other light.
