- Joined
- 23 Oct 2016
- Messages
- 24
- Reaction score
- 0
- Country
Just want to know whether something is compliant with the regs or not.
I want to add a light into our conservatory as we do not currently have one. in the wall next to the door to the conservatory is a double socket on the ring main. there is also a fused switch spurred off of the socket with a 3amp fuse supplying the combi boiler.
My plan was to come through the wall directly behind the socket and put a fused switch in the conservatory directly behind the socket in the kitchen. I was then going to use this to feed a switch at normal height controlling two wall lights.
This was all before I realised that the boiler switch was a spur off of this socket. So....
- Can I legally add this second fused switch through to the conservatory using 2.5mm t&e between the socket and the fused switch and then 1.0mm t&e for the rest with a 5 amp fuse?
- Is it OK to add a light to a ring main for the sockets?
- With Part P in mind, am I OK to do this work between the kitchen and the conservatory and then add the new wiring in the conservatory? The only consealed wire will be the wire that passes straight through the wall - the rest will be in decorative trunking running directly between lights and switches.
