fused spur for underfloor heating
Regarding the RCBO (32amp, 30mA) not all consumer units will accommodate an RCBO. There could be a space limitation and/or no appropriate way to connect it electrically. If your consumer unit contains two RCDs and three neutral blocks then assuming you have enough space there is a chance it will fit. Cane you post a picture of the CU with cover removed?
Firstly, apologies for the huge amount of time that has passed without responding to the great advice I have had thus far but unfortunately for me my line of work takes me away for weeks at a time with relatively no notice forcing me to drop anything or everything else I may be doing!
So, having got back today and if you are still following this thread automation man or anyone else for that matter can I trouble you once more regarding the UFH?
Can I fit a combined fused spur breaker from the ring final to feed the UFH instead of worrying about one at the CU or am I missing the point....again?
The unit looks to be the same sized box as a normal fused switch?
Thanks.
