2 phase and neutral..
19 Sep 2017
Afternoon all, testing a commercial property and its on a 2 phase and neutral supply.
Seperate phases i.e 480 v between phases, previous testers has labelled certain stuff 1/1 and 1/2 etc , question is would guys label this way or would you be labelling 1L1 , 1L2 etc, some might think it doesn't make a difference but our gaffer is insistent on clear labelling.
480 between phases? Sounds high
Labelling- yes it wants to be clear and consistent. I've tended to use a letter for the phase & then a number to ID the circuit- number/number has scope for confusion.
480V is normal for split phase supplies.
It doesn’t really matter how you label things as long as you are consistent across the whole site.
I would normally fit a label which read something like “DB D 7L2”
Yeah its old old switchgear, its basically 240v +240v so I would think its not actually a 3 phase supply but 2 individual single phases brought into the property.
This is why my labelling of 1L1 and 1L2 could be argued isn't technically correct
As long as the meaning of 1L1 etc is clear.
In my experience of 3PH DB's some would be PH1 L CCT1 but others are CCT1 L PH1 but other are DB1 L CCT1
Yeah same cheers
What are the existing markings? if any
As long as the markings are clearly shown on the drawings it doesn't matter.
A UK 3 phase supply would not be 480V line voltage, so must be from a split phase transformer. Is it a farm?
