2 Way Switch
Tof
Sounds like the switch box is being used as the junction box.
Join the neutrals (black) together, with the phase cable (use a volt meter to find the live red) going to the comm terminal, that leaves the switched phase red cable into the l1 terminal.
comms said:
Tof
sorry but i am still a bit confused.
what do you mean exactly ?
Should I join join the black wires together and not connecting them to the any contact on the switch contacts (while the live red cable goes to comm and the switched red wire goes to L1)
or
should I join the black wires together and connect them to L2 on the switch.
Sorry tof I should read the question right through.
From the 3 core cable take the red to the comm of the switch, take the yellow to L1, take the blue to L2.
Now the red from the other cable should also goto L1, Put the black to L2.
All the yellow/green (earth cpc) should be joined at the earthing point in the switch or in a block connector within the switch housing.
I just edited my previous question. can you clarify please ?
thanks in advance for the help.
Have you looked at the illustrations of 2-way switch wiring in the For Reference topic?
