Hi
I have read all the info regarding 2 way switching on this web site. but I am afraid that I am still confused, hence the post.
I have a circuit in the house which contains 5 in number 12V halogen lamps powered via 5 LV transformers. There are 4 switches on the circuit - 2 x 2 way and 2 x intermediate. The circuit works fine.
I now want to remove one of the 2 way switches and replace it with a 2 way dimmer.
At the back of the 2 way switch there are 2 wires going into the COM terminal which are always live - this must be the power in ?
There is a red wire connected to 1 Way ( which I understand is L1 ) and and yellow wire with a red band of insulating tape connected to 2 Way ( which I understand is L2 ). I understand that both of these wires will become live at some point.
When I place a multimeter from the earth on the metal backbox to COM it always reads 240Vac which makes sense as this must be the main feed into the circuit.
With the switch toggled in the up position the voltage on 1 Way is 0Vac, while the voltage on 2 Way is 240 Vac. This seems to make sense.
When the switched is toggled into the down position the voltage on 1 Way is 240Vac, however I expected the voltage on 2 Way to be 0 Vac, however it measures 50Vac ???
Is this normal ? Where is this nominal voltage coming from ?
I want to replace the 2 way switch with a 2 way dimmer, but I am nervous about how to connect in the 1 Way ( L1 ) and the 2 Way ( L2 ) to the dimmer ?
Can anyone help ????
Cheers.
Cheers.
