yeap sorry. thats about heating thermostats
Well, I suppose you could (there's an L, N and switch 'at the first switch'), but the functionality of the circuit as a whole would be 'interesting'Supply at one end, lamp at the other. ... No way to add a second lamp at the first switch without extra wiring.
I've always felt that such an arrangement probably ought to be 'banned', since it can leave one lamp 'out', with both sides of it 'live', if the other lamp blows - but I'm not sure that there actually are any regs which forbid it.It can be done using two same wattage 110 volt incandescent lamps in series.
True, but my point was that if the switches were in an 'ON combination' (and it's not necessarily easy to ascertain which 'combination' the switches are in, when neither lamp is working), both sides of one lamp, and one side of the other would be at full L voltage if one of the lamps were to go o/c.Neither lamp is connected to Live if the switches are in an OFF combination.
Anyway its a stupid idea.
Yup.The Wright brothers were considered to have had a stupid idea about flying machines.
It certainly can be - provided someone else can do it.Hopefully it can be added to the Wiki.
It sounds as if you are trying to get into some sort of global DIYnot wiki or FAQ. This forum's wiki is simply the first entry on the forums's main page - i.e. 3 or 4 entries above the first new post - you just have to click on it, just as you would click on a post.Seems you have to log in separately to the wiki - but username/password does not work, and the 'register' page is blank so no help there.
There is only one.It sounds as if you are trying to get into some sort of global DIYnot wiki or FAQ.
The only difference between clicking that link and the tab at the top is where in the Wiki it takes you - the tab at the top takes you to the top level, the link in the Electrics UK forum takes you directly to the Electrics UK section of the Wiki.This forum's wiki is simply the first entry on the forums's main page - i.e. 3 or 4 entries above the first new post - you just have to click on it, just as you would click on a post.
OK. Fair enough. I'm never tried the tab at the top - not sure if I ever realised it was there!The only difference between clicking that link and the tab at the top is where in the Wiki it takes you - the tab at the top takes you to the top level, the link in the Electrics UK forum takes you directly to the Electrics UK section of the Wiki.
Is that if one tries to use the tab? When I'm logged in (which I automatically am,if I'm looking at the page), clicking on the direct link to the Electrics UK wiki simply 'works', with no further logging in or problems?Seems you have to log in separately to the wiki - but username/password does not work, and the 'register' page is blank so no help there.
Try editing the Wiki.Is that if one tries to use the tab? When I'm logged in (which I automatically am,if I'm looking at the page), clicking on the direct link to the Electrics UK wiki simply 'works', with no further logging in or problems?
