I haven't tried using nail scissors as wire cutters but I have used wire cutters as nail scissors and found them to be highly effective. Makes me wonder if the reverse is true.
I have stripped wire with my teeth and that sort of works. It's not as good as a decent pair of strippers and I certainly can't chew through either the inner or outer insulation of T&E.
I have never found a stand-in for a multimeter. Indeed, mine is usually in arms reach. I might disagree somewhat with the notion that the OP should take German lessons before selecting a meter. Just type "multimeter" into a well-known Internet search engine. For DIY, one generally only needs to be accurate to the nearest hundred volts. Indeed, I've happily done digital electronics with a £4.99 DMM, where one likes to be accurate to the nearest Volt or so.
One accessory II would definitely get though is a set of probes with croc clips on the end. Saves a hole world of pain.
