2007 Petrol Fiesta - Sometimes Problem Changing Gear
WSB
27 Jul 2014
Hampshire
Sometimes I have problems getting my 2007 petrol Fiesta into gear. But the issue is very intermittent and not consistent.
Not sure whether this is pure coincidence or not but find if the car has had a motorway drive, after getting onto local roads afterwards, can be very hard to change gear.
Can go for days though without any issue, then just starts doing it again.
My immediate thought goes to the clutch but was also wondering whether it could be the cable just needing adjusting. Unless of course, it has a hydraulic clutch?
Just looking for ideas, suggestions etc before I take it to the garage.
Best find out which of the two, first!
I seem to remember the cable type, had an automatic adjuster to take up slack, located at the clutch pedal. That auto-adjuster was plastic, and sometimes slipped after a bit of wear.
  • Thanks
Reactions: WSB
Thanks. What is the easiest way to find out?
It will be hydraulic. Do you feel any 'sponginess' At the pedal when you are having trouble selecting gears?
  • Thanks
Reactions: WSB
Can you engage the gears easily with the engine off?
How does the pedal feel? It should be progressive as you press it, from the top to the bottom of it’s travel.
John
  • Thanks
Reactions: WSB
Car has done 11700 miles. Don't think it has ever had a new clutch. Given that info, first suspicion goes to having the clutch replaced.
However, it's the nature of the issue I'm seeing that makes me suspect, this is not the exact problem as a worn clutch would surely be consistently bad rather than intermittent, wouldn't it???
