I even saw they do a 9Ah FlexVolt now... crazy. Quite tempted...
Treat yourself!
Not that curious - like a motorbike engine in the '20s. Around the time Ricardo Engineering invented the 4 valve cly. head The engines were mostly drip feed. Got to hand Honda for miniaturisation of 4 strokes though - the erstwhile Honda 50. et alStihl produce the 4-mix engine.....a curious device that has valves like a 4 stroke but also has a total loss lubrication system, just like a 2 stroke!
Hope this helps
John
Maximum output is typically 10A for a Lithium 18650 cell so you can expect up to 540W out of a 15 cell pack.
My understanding is the biggest Dewalt Flexvolt battery is 9Ah @ 18V and actually only 3Ah @ 54V, though it's slightly misleading (probably on purpose). I saw it rated at about 180 Watt Hours. If you run a 3Ah battery at 20-22A you're only going to get 9 minutes out of it!Those typically found in dewalt, Makita and Milwaukee are 20-22A
