N
namsag
Can you explain how something smaller than 22mm can be a tighter fit than something designed for 22mm
3/4 is a tight fit onto a pushfit fitting. If anything it is more secure than onto a 22mm pipe.....and yes it is not recommended, and yes sometimes the fit is too tight and you pinch/split the rubber seal.....it was just another suggestion. In an ideal world end feed 3/4 to 22mm or 3/4 compresssion olice.....
¾" is smaller than 22mm so will flop about in a pushfit fitting and blow off as soon as the pressure was up.
yeah, that's why i said i wouldn't do it deliberately
