24v dc voltage drop calculations
MILESON,
If you are generating 24V. D.C. unfortunately (as pointed out by the bickering 'gentlemen' on here) will not be practical to transmit over that distance.
Without getting all technical 800watts @ 24V = 33.3 Amps, and would give either very high volt drop or result in a very large cable to cut losses.
Depending upon intended type of load an answer might be to connect to a local 24V-230vAC invertor as used by truck drivers to power mains equipment, then at 230V your cable would only be carrying around 3.5A and a 1.5mm cable would probably be adequate.
regards
[Hello all what a great response and that was first time on.
I think the general opinion seems to be to carry the load over that distance at 230v which does make sense and gives us a lot more choices of actually using the volts.Thanks again
Mileson, slight error, over 120mtrs would need a 4mm swa to keep volt drop to acceptable limit eg, 4.62Vd still better than a120mm2 cable at 24v!
regards,
