Hi to all,
hope someone can help me with a WB 28si II,
just back from Hols and the local water company have upgraded the water main in my street.
I now have great cold water mains pressure, but there is a constant gurgling noise from the 28si ,(literature says DHW max 10Bar)
Also when I turn on the 28si the boiler kicks into life(fires up ) with no taps or CH on !!
if I then turn on a hot water tap the heat varies and pressure is poor if tap is then turned off the boiler still keeps firing and I have to turn it off at the 28si on/off panel switch to stop it ,(guessing it's seeing constant flow though the turbine ??).
The hot water pressure is very low all over the house non existant upstairs , and to make things even worse ,the CH system (1.5 bar, looks ok) will only kick in if the mains stopcock under the sink is closed !!
I system is about 18 mnths old if
anyone can giv me any pointers, i.e is the DHW system pressure fed thru the heat exchanger,could the upgraded mains pressure have blown something ?
Thnx
Thnx
