Thanks. I've taken the control panel off and managed to remove the cap from the pump. A little bit of water came out then it continued to trickle lightly for a little bit longer. The center part of the pump seems to move fine so not so sure if it is the pump.
Also one thing I forgot to mention; if I run the hot water then of course the boiler fires up and continued burning. If I then turn the hot water off the boiler stays burning for a few seconds and the CH kicks in then the burner stops.
