Both photos are the same.
oops sorry here is the other one my mistake
//media.diynot.com/217000_216565_74915_98393558_thumb.jpg
cheers
I take it in the first picture, left hand side, the brown in the common is from the 3 core+earth cable, and that the brown with the black wire goes to the wall lights?
between E and SL = should (must) be 240Vwith ceiling lights on at the ceiling rose i get the following results
between N and L = 0v
between E and L = 244v
between N and SL = 244v
between E and SL = 0v
working through your tests you have definately confused neutral and SL.HI EFLImpudence
Thanks again for the response here is my answer hope you can help from the results.
With ceiling lights in both off positions wall light work
with ceiling light off at the ceiling rose i get the following results
between N and L = 244v
between N and SL = 0v
between E and SL =
(SL) = switch live wire
Thanks Again
Graeme
between E and SL =
Thanks Again
Graeme
How are you being so certain you know which is neutral?
To double check,
Test between E and N, that must always be zero.
Between L and N must always be 240 v
