under-plinth/kickplate heater..Winterwarm by Glenn/Dimplex.
Have a double socket on ring main available for this..I was going to connect the heater to the socket with a 13A plug (heater is just over 8A?).
Nothing else will be permanently plugged into the other socket in the double socket.
Just noticed they say must " incorporate a double pole isolating switch having a contact separation of at least 3mm". I am not sure if the socket is SP or DP..they are unused but I bought them ages ago...afraid I have chucked any packaging...& no makers mark on front.
If it is really necessary I'll buy a new DP socket for this job. It's not the cost obviously but the socket, though accessible, is going to be a pig to swap out because its at the back of a unit.
So it's a technical question really..why isn't a SP socket apparently sufficient?
If it IS vital I'll swap it..but if it's not..I'd rather not..plenty else to do right now.
