I am removing a "lovely" false ceiling in the upstairs hall, and this is the first time I have looked at this part of the lighting circuit. It is a two way switched circuit (downstairs/upstairs) switching two circular lights in the upstairs Hall.
Upon inspection the main circular light is fed from the ceiling rose, however the second light has been connected with a terminal block between the ceiling rose and light. This was tucked up between the light unit and the false ceiling...
The circular light will be going in favour of a pendant light. What would be the best solution to keep the two lights/one switch arrangement that I have? The ceiling rose is wired as loop-in so is already quite crowded in there - I don't fancy my chances of fitting the 4th cable in there whilst hanging over the stairs! I am thinking that a Junction Box in the loft will be the best way to go.
Mal
Mal
