In re-instating a partition wall the previous owners took out, I'm wanting to see if i can re-hang the door to open against the adjacent wall, rather than into the room.
However, the existing twin dimmer light switch is on the wall against which the door would open.
So, I would either need to re-wire & move the light switch into the re-instated partition, or find an alternative approach. One possible idea i had could be to use quinetic switches. Does anyone know if i would be able to fit 2x wifi min receivers (https://www.quinetic.co.uk/products/wifi-mini-receiver/ ) into a 50mm backbox and if they would work ? The operating switches would be less than a meter away.
From the spec sheets it looks like they would just about fit, just not sure if they will work or if its a good idea.
