Morning all,
I tried to fit 3 wall lights last night to existing cables. Lights have not been connected since I moved in.
A 3-gang switch controls 2 ceiling light and 3 wall lights. The ceiling lights each have their own switch so I assume the 3rd controls the 3 wall-lights. 2 lights are joined in parallel and 1 direct to the switch (so 2 cables into the switch for these 2 lights).
The lights are on a non-RCD circuit but...
When the L/N ends of a wall light touched (when dead), the RCD tripped. I could not re-set the RCD until I separated all of the cable-ends at the 3-gang switch.
The 2nd issue is that I am reading 3 volts between the galv capping of one of the lights and the Neutral.
I append a pic of the switch. I only had a short while to examine the cables last night but it only appears that there is 1 live feed. 3 Neutrals were joined in a block. 1 Neutral snipped off. Earths twisted together. A real mess. Do RCD's have a time delay when tripped, before resetting?
Any ideas re 3V capping-Neutral?
Any ideas why lights would trip RCD
How to rectify?
Thanks,
Alex
