with a 3 port mid position mot. valve - if the motor fails you can manually open the valve fully and hae heating on when hot water is calling - until the hot water is satisfied.
but if the hot water isn't heating up, can you manualy open it via the lever or to midway when heating is on, to get hot water also?
I have tried this but it doesn't seem to work - why is this? i think my cylinder stat has failed so until i get a new one and change it over, have no hot water.
is my 3 port valve ok or is this just how it is supposed to work?!!
another thing i have noticed is that when heating is on only the lever does not automatically move across, which i thought was supposed to happen to indicate the motor had moved across inside - although obviously heating is on and the valve seems ok. it is honeywell, grey in colour.
thank you for any help or guidance you may be able to offer me.
