so it has proved the cyl stat is not switching (making) when it should be (ie should be caling for heat). it is probably stuck.
and that the programmer is ok.
do you mean tape the wire at the end on the uninsuated bit? i know it will be live, and i know where the wiring links up, ie i have a layout and good idea of it. it's just the following:
i have just turned heating on (but like the other day) got no hot water when heating was on do i need the heating on full temperature on the room stat dial to get any hot water?? won't the 3 port be on the heating only position, thus closing the h/w side off?
