Thank you for spending the time on this.
Haven't cracked how to copy messages but here are the answers as far as I know:
1. The plywood was WBP exterior grade. It was fixed direct to joists with screws and "no more nails" glue.
2. I don't know what acrylic primed means but I don't think it was done.
3. Not sure about primer
4. Tiles are porcelain floor tiles...about 20cm x 20cm
5. Span of joists in problem bathroom is short as it is in a loft extension which sits on steel beam frame/cage if you know what i mean....two steel beams run either side of bathroom and joists run from steel beam to steel beam...I would say span of wooden joists is 6 ft at most.
6. Re grout full depth, I tried getting a coat hanger in to the hole between floor and grout...it runs in about 5 cms from the edge of the tilework...but the cracking is in the middle of the floor...I can only conclude that there is empty space under the cracking as the grout is falling through
7. See my response re addy used. I'll check later
8. Re floor flex, I almost can't believe it is happening given the small space involved...there is a full length bath plus toilet and sink but only room for two people standing besides all of that!
9. Builder was recommended for this type of work. The whole project became a renovation of three bathrooms which were not in bad condition...just wanted to update/improve. Other work included work on floors in bedrooms and complete repainting.
10. Noted re grout around the bath.
11. Should all perimeter edges of a tiling job be silicone rather than grout...to allow movement?
12. The ply is on the floor...its not a wetroom. The walls are plasterboard.
13. By first chance I mean, I expect a professional to get it right first time...this wasn't a technical job by any means as far as I was told
14. I can't see if there are gaps between tiles and floor...the gaps I am talking about are between the floor and the underside of the grout i.e. the grout appears not to completely fill the spaces dividing the tiles
15. I don't know what trowel was used
16. Ivory grout was used
17. Can't see there is any sign of adhesive failure but perhaps I need to test a bit more? Any tips on this?
18. The tiles in the problem room were different from the other two rooms...the grout for the other rooms was a Black Bal Microflex grout which is not showing any problems as yet
Thanks again for looking at this. I need to find out what mix of addy was used and will report back. [/list]
