32A PDU to 16A "commando" socket
1 Jun 2011
Berkshire
Hello,
We have a PDU/Power Adapter that fully loaded can take up to 32A.
However, we're only going to be loading it under 16A. The wall socket is a 16A commando.
Can I replace the 32A commando socket on the PDU with a 16A commando socket as we're never going to be drawing more than the 16A?
However to future proof it in case someone overloads it further down the line ... I understand these are not fused, can you get a 16A "fused" commando socket? What's the best options here to make sure the PDU never pulls more than 16A?
(On a side note, anyone know the difference between a 2P+G and a 2P+E commando socket?)
Thanks!!!!
If your 16A outlet has been properly installed then it should already be controlled upstream by a 16A protective device (or perhaps 20A at most, though more unusual). You should still be careful to avoid overloading the outlet, as a 16A OCPD isn't going to trip the second you draw more than 16A, but there's nothing inherently unsafe about changing the 32A plug for a 16A.
71686_P
Just swap the RCD for a 16A circuit breaker.
It ain't cheap though :eek:
Do you have a picture of this PDU and of the "socket" you plan to replace on it? when you say "socket" do you really mean inlet?
