Can anyone think of any solutions to connect up a 32mm OD Spazio/Franke style space-saving basin waste tail with a short 36mm OD solvent weld tail please?
I've already tried a fermco which won't fit due to space restrictions (it's too long and causes the pipe connecting with the waste itself to foul the drawer in the wall hung unit).
All normal 1 1/4" or 32mm fittings I can find are for use with the usual 35/36mm OD push fit or solvent weld pipe, as you'd expect.
I took the waste apart to clear a blockage and don't want to bodge it back together as the builders did.
Their solution was to put the smaller pipe inside the larger one and silicone the lot together.
Any help much appreciated.
