36 mm waste pipe adaptor
2 Dec 2019
My sink plastic waste is the old 36mm and i can only find 32mm or 40mm elbows and pipe....is there an adaptor available anywhere or are there any stockists of 36mm...cheers
Just checked again ...the plastic welded on bends say 36mm so would that mean the pipe is 34 mm...
Solvent weld 36mm, push fit 34mm Osma quote 32mm for both. I presume you mean the wash basin? What fitting do you want?
Yeah its a sink bowl with a low waste..the bowl sits on a worktop
You can either do it in solvent weld fittings and a pot of solvent weld, or use a McAlpine mechanical (compression) fitting that will fit both solvent weld and pushfit.
What are you trying to do?
As others have said, 36mm is normal solvent weld pipe/fitting OD diameters, it has an ID dimension of 32mm. Any pipe and fitting that is designed for solvent weld (glued or compression) will fit your existing.
