What's wrong with calling someone out to jet it for you? Get a fixed price and not an 1/2 hourly rate and you will be fine.
Andy
Andy
Contacted a local jetting company who said they charged a fixed price of £55. That includes one of hour of jetting but they basically said if it could be sorted with jetting then it would be done within an hour.
Doesn't look to me like the roads are touching the brush? Seem to be jamming on something just before the target. My money is on that is a lump of fat behind the brush, chemicals wont do much if they aren't in contact with it, there's space for flow to get past so they wont achieve much.
I'm with Andy, get it jetted. Jetter should firstly pull or push the brush to a point where it can be removed, and secondly, scour the walls of the pipe to remove any build up of deposits. Jetting something up there to retrieve the brush is one thing, but removing the crud behind it satisfactorily is another, given the layout of the drain, you wont do it with rods.
Yes, very cheap. Just make sure there are no other charges like machinery use.
Andy
I have already told you what to do, Homeserve £9 for first 11 months and up to 4 calls, then just cancel it !!!!!No other charges. They said they will try their best for an hour, if they can't fix it then I guess they'll give prices for other work to sort it.
it is a sink drain is it not ? totally your choice
That looks like a flue brush and should never have been used in your drains .......thats what it looks like to me.
Have you got access both ends of the blockage ? If you have I'd try and pull it back from the direction it went in if you can.
Try and get a line past it and then draw a thicker line through until it's thick enough to tie something to it that will not go past the brush nor break and pull like hell.
It's a solid object, chemicals won't do it bit of lateral thinking on this one.
