but combis break down much more often than regular boilers.
no-one will seriously attempt to deny that.
...Do you consider Plate Exchangers to be get blocked often?...
If the combi is being fitted on the ground floor,the pump in it may struggle to heat the rads on the top floor,so maybe not just the hot water deciding what you fit.
You are passing off a poorly designed and installed system as the norm.
Ditto. Experience. Something you wouldn't know about.This is nonsense.
But he's got what he's got, he isn't going to replumb the entire house just to satisfy your perverted opinion.First, the mains pressure and flow must be capable.
Secondly, the water system MUST be installed properly.
the problem is space. A silly answer.fit a cold water accumulator
A pump on a combi or any other systems will be in exactly the same situation. Being a combi is irrelevant.
No. I'm going by experience.
Which you don't have.
You don't need as perfect a mains supply if you store water. Surely even you can understand that
Well you can tell that to the customer who last week needed a pump changing on his combi boiler. The pump in question was a Wilo, but specific to the appliance. It cost £189 just for the pump at trade price. A similar wilo pump for a standard system can be bought in screwfix for about £40.
