Whilst decorating I decided to convert the current surface mounted double socket (which is on the skirting) to a flush wall mounted socket above.
When I took the front plate off it was clear that there were 4 x 2.5mm wires going into it which was a bit of a surprise i was only expecting to see two as part of the ring. I don't know where 2 of the cables are going as they run towards the landing and under fitted carpets etc and without lifting all of this I probably won't find out although I am a little concerned that this maybe a seperate ring running off the socket.
Either way the new wall mounted box isn't deep enough to take all four cables and it would be a bit of a pig to run all four up the wall to the new socket so could I join them all together under the floorboards either by crimping or by a junction box and then run one cable up to the socket?
That way wiring the new socket will be easy and the circuits wherever they may go will still be complete.
