4 x three core cables for one light and switch?
Well, the circuit and wiring is usually protected at a minimum of 5 amp, so one wouldn't usually fit a 3 amp connector on something which effectively runs through the whole circuit.
You need to put 3 or 4 wires into each one. The 3A type are too small to fit multiple wires into.
Thanks guys. That makes sense. I'll need to get a 5amp + terminal block. I'll get that tomorrow. The only outstanding thing is trying, without getting a meter, to work out which is the switch live.
You know which incoming cable at the ceiling is the feed. Connect the live (brown) from that feed to each of the other browns in turn, and making sure that the other wires are separated each time turn on the power and check for voltage at the switch.
As a double check, then test for voltage at the corresponding blue wire at the ceiling outlet while somebody turns the light switch on & off.
with ALL of the ends in connector blocks! Don't do this with any bare copper showing
Me again. With more home electrical madness.
Sorry to be the bearer of what you may consider unwelcome news, but the madness is not in the wiring, it is in you deciding that it is OK to fiddle with your wiring when you don't actually understand how it works.
Wrong.
DO NOT DO IT AT ALL.
Trying to do electrical installation work by trial-and-error, "let's do this and see what happens", guessing and hoping to find the right combination, is a stupid thing to do, and PBC's advice was [expletive-deleted] irresponsible.
